77 70hp carb questions
txbandit44
OK few quesitons here
One of the carb bases has a jet stuck in it. Stuck so bad that i broke my brand new OMC jet tool.:mad:
Good news is it looks like the jet is clean and I could just put this all back to gether and run it. But I have a problem with not doing it right.
so to the questions
Can you still get the float chamber assy? Not the middle carb with the fuel inlet.
Are all of the orifaces in the float chambers the same? The other 2 carbs have .54d stamped on them.
eavega
Re: 77 70hp carb questions
All the high-speed Orifice are the same, 54D. As to the float chamber assembly, there are a couple of online retailers that have them available. The middle carb float chamber is showing as obselete.
Rgds
patrick4266
I have that float chamber that I will give you. Send me a pm and I will give you my phone number.
