CynicalOne
Thread starter- Joined
- Jun 3, 2013
- 15
Here's what I have -
Bought a 85 Ranger 340 V with an apparent 115 Evinrude. The guy I got it from said it ran fine up to about 3/4 throttle but would die at WOT. Said he rebuilt the carbs and put a 12psi electric fuel pump on it and it still would die at WOT. I verified that it WOULD run before I bought it and since I was getting the whole package for near nothing, I figured even if I had to tinker with the motor I could still be ok.
What I found out after I got it home is that it wasn't the engine he thought it was. The button on top says 140883c which means it's a 78 140 not a 115. So from there I first ordered the proper manual fuel pump (knew the electric was a no-no) and a set of carb kits going by that model #. Rebuit the carbs, installed the pump and it started on muffs within minutes... GREAT! Took it to the river, started and warmed up fine ( a little cold) and took it out to she what she would do. On the way out, it died a couple times and I noticed the primer bulb was flat. Back to the dock and replaced the bulb. Back out ran fine. Opened it up and I was happy... up and on plane fast. Tried this several times and was content. As this was just a test run, I headed back to the dock. Pushed it forward, planed out.... and died. Restarted after a couple of attempts, pushed forward, planed out... and died. Did this 3-4 times back to the dock, but seemed to run fine at lower revs.
It was suggested that the power packs may be getting hot and killing fire at WOT, so I ordered 2 new ones going with the #140883c. Received those... and they're wrong. Actually before I got them, I discovered they were wrong. Looking at my ignition and with some digging, my ignition is from a 77 with a SINGLE power pack. Maybe this engine was an EARLY 78 model? Either way, got the right power pack replaced and took it back to the river. Again, the primer bulb would go flat. Since it was new, I knew there had to be a restriction to the tank. Worked it out and pushed it forward... planed out and... died. Different this time as it seemed more like it ran out of fuel than just died. Back home and replaced fuel lines from bulb to tank, installed new filter and pumped it up. As the fuel hit the filter I saw it fill with trash. New line, so it had to be coming from the tank. In short, I removed and cleaned the tank, new fuel... new filter. Back to the river and the 'dying' is gone. But it runs like crap. Top RPM is at WOT is 3800. Read in the manual this should be about 4500+. Engine misses thru all ranges and sometimes stumbles and dies at idle on muffs.
So here's the list of things done -
New fuel pump
New lines and tank cleaned - Found a couple foil seals from oil bottles in tank. This was my restriction
Carbs cleaned and rebuilt
New power pack - but it runs the same with the one I replaced
Checked and verified all wiring is correct per manual
Using inline tester verified spark on all Cylinders
Compression is 120, 120, 120, 110
Did a 'link-n-sync' per manual
Engine starts fairly easy when cold and will start instantly when warm.
Runs rough thru ALL RPMs - Missing, coughing, choking, sneezing... whatever you want to call it.
I'm stumped... HELP??
New fuel pump
