Finished up the installation of rebuilt 302. Hooked everything up, cranked it over and no start. Carb is getting fuel, plugs are not getting spark. Looked my manual over and the instructions are vague regarding troubleshooting the ignition and I don't have the "magneto analyzer" called out in the manual. I checked everything I could with a volt/ohm meter. The resistance wire to the coil checks out ok. I have 12v at the high tension terminal with the key 'on'. I also have 12v at the dist. end of the coil high tension wire. I have removed the points, filed them, and re-installed them with .019 gap. I'm not sure what to check next, any suggestions?
