Bdt 1967
- Joined
- Mar 4, 2008
- 76
My Evinrude will not idle correctly upon start up or after sitting for a while, the engine will try to die every time that I attempt to put it in gear, after i run the engine for about 5 min at anything over 2000 rpm it runs great, I can go from neutral to forward and neutral to reverse, but after i shut the engine off and sit for a little bit it has the same problems all over again it tries to dies and wont start up right away. In an attempt to fix the problem I
-Rebuilt carburetors
-New sparkplugs
-New gastank
-New fuel lines from tank to carbs
-New fuel fittings
-New fuel tank pickup
-New primer bulb
-Seafoam
-Good compression
All this did not fix the engines idle. I then noticed a leak from my fuel pump, about 1 drop every second when its not running. I rebuilt the fuel pump and now i have no leaks. I have not tested the engine but when i take it to the lake this weekend if I still have the same problem do you guys have any suggestions as to how to fix it? I dont think its timing because the boat runs great when its been running for a little while. Any help will be appreciated, It idles around 700 rpm.
-New sparkplugs
-New gastank
-New fuel fittings
-New primer bulb
-Seafoam
-Good compression
