dwco5051
- Joined
- Sep 14, 2008
- 2,568
Re: 77 Evinrude 55hp stalls suddenly
There is a good chance that you need a new water pump impeller. Don't know if the engine sat for a few years or is someone ran it dry. I use one of those infrared thermometers for checking the heads. Just point, pull the trigger and get a instant digital readout. I think your motor should read between 140-170. I used to be a HVAC contractor before I retired so some of that stuff that fills my shop still comes in handy. A new impeller is a lot cheaper than new pistons and boring skuffed cylinders. Usually an easy job for anyone who doesn't have to turn a screwdriver both ways to see which way it tightens
Once you get over 115hp or so it can be a two person job just due to the weight of the lower end and making sure everything lines up.
