bassfisher2010
Thread starter- Joined
- Mar 21, 2013
- 18
OK I have a fairly healthy 77 115. The compression is 125 on cylinders 2,3,4 and about 122 on #1. I have her mated on the back of a 16ft venture magnum tri hull bass boat with stock prop and properly set Jack plate. Also installed transom saver after I had to rebuild thet ransom. Anyways what kind of fuel mileage can I expect? I have a 13 gallon tank with a spare 5 gallon. And can't fuel at marina BC 1 its about 1.00 more a gallon 2 ethanol and 3 water in their tanks. Should that be enough fuel for a days ride? Also any guesses for top speed with 2 people and light gear? I will be taking her out for the first time Monday. Also engine is ready for a decarb is 1 gallon pre mix and one can sea foam the right mixture? Will I gain some slight compression? Thanks
