mudweiser
- Joined
- Jun 21, 2007
- 115
I'm etting a 77 johnson 115 v-4 up and running on a 1977 Ranger 1750. The ignition system has been checked and necessary repairs made. It's timed and syncd properly. Carbs were rebuild last season along with the fuel pump. The engine cranks right up but does show some fouling at idle. If i flip the warm up lever, the RPM slowly climb and clean out the engine. When i mash the throttle, the engine pulls but hessitates, sounds like a miss. I verfied it's not missing due to ignition. Keep the throttle pinned and the engine cleans out pulling about 5,000-5,500 RPM's. You can hear it surging a bit, ok surging alot when running at WOT. If i squeze the primer at WOT, the bulb is hard and squeezing more does not change things at all. If i hit the choke for a split second, it falls on it's face. spark Plugs do show a rich condition. Compression is good and engine has been decarboned. The longer i run it, the better it gets. It does use a ton of fuel which you can smell and see on the fuel gauge. However the problem retruns when i let off the throttle. If the engine sits shut off while i'm fishing, i can hit the key, mash the throttle as soon as it starts and it's fine (pulls RPM's right away but still surges) when i let off and hit it again the problem returns. The fuel pump was just removed and cleaned the other day, everything looked fine, it was rebuilt last season. I moved back to the carbs, removed them, checked to see that all the jets were correct for the engine. The carbs were cleaned, jets removed and cleaned. Floats are plastic and were set so they are level / parallel with the carb body. Needles and seat were new last season and look to be in good condition. Once assmebled, i flip the carbs upside down and using a vacuum tester i can pump it to 10 psi and the gauge drops fast. Are the needles leaking? With the carbs back on and hooked up, i can prime the fuel system and if i keep squeezing the primer bulb i can flood the carbs and get fuel to flow out the venturi. Guessing bad needles, bad floats? Needles are cheap money (Sierra) so i'm going to replace again with Sierra. How do i know the floats are good?
