Greg Boswell
- Joined
- Oct 19, 2012
- 46
Re: 77 Johnson 115 won't hole shot without choke
Was thinking about this some more. Almost every other minute it seems.
Anyway, is there some place the crankcase could be prone to developing an air leak causing the lean out symptom I'm experiencing?
Just seems odd that it ran so well and just having the carbs rebuilt to stop leaks and putting on new fuel lines and control cables would be causing all this.
Really, seems like the motor just coincidentally started developing a vacuum leak someplace that I can't readily see or hear. Maybe there is someplace specific I can look or be directed to if these engines have a known spot or possible area that could cause this kind of issue. The reason I say this is because I launched from up in a canal when I got it back and had to putt along at idle speed for almost half a mile, so if something was ready to blow out, it had time. By the time I got to where I could go full speed the motor had been running for at least ten minutes. Not trying to detract from any other possibility, but seems like benefit of the doubt to the carbs since it seems the fuel pump is off the list. I will still pull the carbs back off as soon as I can. Tomorrow I'll call and see if the shop can remember if the jets were changed out. Kind of doubt they'll remember, but worth a shot.
Any thoughts? Thanks for any input.
