So my motor runs fine going forward from neutral all the way to WOT, but it lacks any actual power in reverse. I have a very hard time even getting off the trailer if there's any wind/waves. The controls are Evinrude, and the lever goes back about 3/4 of the way but hits a side cushion and can't go any further. Still, with the amount it does go back, i should have more throttle than i do (less power than the first "click" in forward, even with reverse pulled 3/4 back). Is there an adjustment on the throttle cable that i should check? Are there 2 throttle cables total, 1 for FWD and one for RVS? I always figured i'd have to swap out the controls for a shorter lever, but a friend told me there "should" be an adjustment somewhere to determine the amount of throttle given in reverse gear, that doesn't affect forward throttle. Is this true?
