The engine starts great and runs fine at idle or slightly higher, but when I try to accelerate, the engine simply dies. About 50% of the time, I can squeeze the bulb until hard (while running), and it will accelerate and run as normal. Occasionally, the engine will falter at high speed, gradually dying. When this occurs, the bulb is run flat.<br /><br />I tried disconnecting the crankcase line from the fuel pump, and there is no change in operation (?????). There is fluctuating pressure on this line, however.<br /><br />I have replaced the fuel line and bulb (OEM) with an aftermarket unit (Tempo), dis-assembled and examined the fuel pump (seemed ok), and finally replaced the fuel pump (with OEM part). No improvement. I have two fuel tanks, and the problem occurs with both. Fuel is fresh.<br /><br />Any advice would be very much appreciated!!!
