MRneatfreak
- Joined
- Feb 20, 2012
- 138
Had this motor for about 4 months. Done alot to it covered in another thread of mine.
http://forums.iboats.com/showthread.php?t=539676&p=3700390#post3700390
It has 3 new coils, new plugs, new powerpack, new impelller etc.. Ran great for about 6 hours yesterday, we stopped at the marina and refueled, 5 minutes after leaving hit a rogue wave in the bay, one of passengers fell out of her seat, so I throttled back to idle, went to power up and it died. Thought that was weird, went back to neutral, it started again but after more thottle died in gear. It finally got to the point where it wouldn't even idle. So I intially checked/dumped the fuel/water seperator into an oil sock, didn't see a whole lot of water, then decided to drain the carb bowls just to be sure. Didn't see much water separation come out. It just cranked after that, with an occasional chug but nothing that would go back to an idle. I pulled each plug wire one at a time and using an old spark plug I had I checked all four leads for spark, and there was none. Didn't see any bad wiring. It would make sense that it had something to do with the timing advance, as it was idleing fine but upon full throttle it attempts to go but dies. So I played around with that but nothing. Ended up calling TowBoat US for a 40 minute tow back to the docks.
I started troubleshooting today, checked the black/white wire for volts with key on and off. In off zero volts, in on .9 volts. Not good right?
Then I checked the brown/yellow and brown wire for resistance and read 975 ohms this checks the stator. Any idea what thats supposed to be?
I haven't ever changed the stator, timer base or the charge coil, or the rectifier.
