'77 Merc 115 Loses Spark
firediver3
I have a '77 Mercury 1150 w/thunderbolt ignition on a 17' Tri-hull Bayliner. The problem that I am having is sometimes the motor works fine all day and other times it will have no spark at all, to any cylinder or the cap. I have tryed checking for corrosion on all terminals and have tighted them to the specs in the repair manual. When this happens it can be at high or low RPM's or when trying to start, even after running fine moments earlier. I hope that someone can help me, the only shop here that will work on it has a 4 weeks wait to get it in to look at it.
ODDD1
Re: '77 Merc 115 Loses Spark
ok. firediver....you need to find out if this is a power supply prob or a trigger prob......the switch box mounted in front of the carbs..on the 4 terminal side you should have 12v on the red terminal ALL the time....on the white terminal you have 12v when the key is turned on...next time this thing doesnt start get out your trusty 12v test light and make sure you have power on BOTH those terminals...if you dont you have a harness connector thats corroded up or wiring/key switch probs..all relatively easy to fix......if you have power on those 2 terminals and no spark,you will need some fancy test equipment to verify what has failed....but if your a bettin man, go with this...these coils almost never fail, switch boxes do, but when they do they fail completely and dont come back....now, 95% of the time you have a no spark situation is because of the trigger failing...classic failure is good first start of the day and after heat build up will fail...the trigger in these units is the distributor housing itself...you have to pull the distributor off the motor and do a complete teardown,assemble correctly and retime the engine...not a job for a rookie.....for your sake i hope its one of the former probs and not the latter.....
firediver3
thanks i will try the test light first before going any further into it
firediver3
I ended up replacing the distributor housing and took it out on the lake Saturday runs like a champ again. Thanks for all your help
