Ok this one is kinda weird, i still havent figured out what is exactly going on.
About-
1977 Merc 1150
good compression 120psi +- on all 6
just cleaned the carbs
checked spark on all 6 - good
new wiring - everything matches wiring diagram
new fuel pump diaphrams on the way
etc....everything is in good working order
So i have been working to get my boat on the water for a while now...(its a 69 marlin that was in rough shape) and now i am to the point to get the motor running good, and have came across a timing issue that doesnt make sense to me. Any suggestions would be appreciated.
I have the service manual for the engine (if anyone needs it let me know because its on a cd and can email it) but anyways i read the timing section and have kinda stumped myself.
So the motor runs, but idles rough, on water the maxiumum rpm it will get up to is 4300 with a 13" by 19 pitch prop on a 16' boat. so not what it should be. so i got a timing light and set it to spec. 8 idle, 21 WOT...doesnt idle. tryed timing it by ear for the hell of it, and it was wayyyy advanced when i could get it to idle. so i pulled the distributor pulley cap and checked the timing marks and found something that doesnt make sense. SEE IMAGE BELOW
So the flywheel has a line on it that is about say 30 degrees couterclockwise of the 3 dots....the pulley on the distributor is lined up to the line. When i timing the engine with the light, i timed the 3 dots to where they should be... so it seems like everything should run right...but it doesnt...
so do i rip it apart and adjust it to were it should be? or is this set up like this for a reason that i am unaware of? And since it is set up the way it is...how did it work out that i have spark on the #1 at TDC, and it dont run well at all? I expect that most of you will say to set it back to the book (i plan on this). its just kind of running me in circles right now.
wow sorry that was kinda long. hopefully it made sense, ill be checking back in a few hours..so post away(please). thanks!
About-
1977 Merc 1150
