I have a Sea Ray 260DA with twin 165 Mercs. The port engine runs great on earmufs in the driveway. The Starboard is the problem. The last time out the alternator belt broke and the engine died. Guages did not spike for temp on either engine. I limped in on the port engine and pulled the boat. Due to many factors the boat sat in the driveway for a year.
I got the belt replaced and the engine would not turn over. I replaced the slave solenoid, which was visibly broken and the starter engaged. The engine will not crank. Pulled the plugs, still no crank. put oil in the cylinders to free up last night. The oil does not appear to have water in it and is not milky. There was some condensation in the valve cover so the oil will be changed.
At this point I plan to do the following.
1. Lower drive all the way.
2. Try to crank again, if that fails then
3. Pull outdrive and see if it spins free and try engine again.
Am I missing anything? Is there anything else I can try? I am really trying not to pull the head off of the engine. Any suggestions are greatly appreciated.
