greasemonkeyjmj
Thread starter- Joined
- Jul 7, 2008
- 264
i have a 77 nerc 500 that has been sitting since 1992. i did some rewiring and carb work and it seems to be running good. but my concern is that, the tell tale only put out a stream of water about 4 to 5 inches long, even at high idle. i have installed a new impeller, everything in the pump housing area looks good. i pulled all of the old rubber out that i could find and even pulled the water pickup screens and cleaned out the bits.i blew compressed air through the telltale hose and it sounded as if it was open with no blockages.due to transom problems with the boat, i havent ran the motor in the water, only on muffs.i seem to have a good flow of water out the prop hub, there is none out of the ports below the cowling. also there is water coming out of the holes right above the cavitation plate, above and to the front of the trim tab. is this normal ?
