Bradmph
Thread starter- Joined
- Aug 30, 2009
- 24
The boat has not ran well, so I checked plugs and found tiny water droplets on plugs. Mostly on No.4 and just around the edge of the plug. I decided to remove powerhead to see if I can locate the problem. After removing the powerhead, I found water puddled in the exhaust plate in the driveshaft cavity. I included some photos of both the powerhead and exhaust plate sides. I need some good help on this one if anyone knows where it probably is coming from.
Comp Test:
1=115
2=120
3=115
4=120
The boat has only been hooked up to a hose so far because it would not idle for more than a minute and dies soon as it is put into gear when I went to the lake quite awhile ago. It takes a big squirt of fuel directly into carbs to start and then dies after it uses it up.
Comp Test:
1=115
2=120
3=115
4=120
