78 35HP Evinrude pops about every 20 -40 seconds on idle
larrybr45
My engine makes a pop sound when on idle, and will die many times then. I replaced the plugs like suggested and started to turn the idle screw to more rich. THis seemed to start to help a little. I tilted the engine up a little to get the fuel pump part # and noticed the carb was about 1/2 inch away from the engine block, it appears that two bolts holding it were loose. Would this separation from the engine block potentially cause the pop I hear and the stalling?
I am going to replace the fuel pump this weekend.
thanks
fireman57
Re: 78 35HP Evinrude pops about every 20 -40 seconds on idle
get new gaskets and tighten your carb. Can't believe it even runs sucking this much extra air. Your fuel pump is probably fine
boobie
I can't believe it even ran with the carb 1/2 inch away from the block.
