After many hours of frustration, reading seloc's over and over, and even aquiring the help of my dad, I turn to you the experts.
First off I consider myself very mechanicaly inclined but lacking in motor/boat experience. Please take it easy on me.
Specs:
1978 Johnson 35HP MD#35EL78R
15' Lowe Line Aluminum Boat
Remote steering consol with electric start/choke
Back Story:
I was running this boat WOT and it kinda bogged down, almost like I was lowering the throttle 3/4 of WOT then down further about 1/2 of WOT. They phhhffff....nothing.
No chance for a restart. Got a tow back to dock....
What I've checked thus far:
Fuel filter...clean
Fuel pump...good flow (thought I lost the pump when it died on the lake)
Checked/replaced all fuel lines/clamps
Spark...good
Pulled plugs....I get fuel/air mixture when cranking over
Rebuilt carb...good fuel flow to bowl, float working, no build-up inside at all very clean.
Two things that I see as possible problems;
1) When cranking over with electric choke or manual choke engaged, I get a small ammount of fuel out the front of carb, and I get a 'back fire' sound after 4-6 revolutions of the motor.
2) Also cranking seems 'slower' or like it's having trouble cranking at random times, then the next crank it seems to crank just fine, and it almost starts I actually get a few 'fires' in the cylinders if I move the throttle to about 2/3 of WOT.
any help or advice is much appriciated in advance.
-Matt
EDIT* I forgot to mention one more thing, I'm leaning towards a fuel pump/fuel problem still, because if I use the choke it won't start, but the attempt right after a choke it almost always attempts to fire.
Specs:
Back Story:
Fuel filter...clean
Spark...good
-Matt
