78 70hp 3 cyl water pump
olemana
This is my first water pump install!!
Exactly which way does the pump impeller go?
Where am I going wrong?
The drive shaft turns to the right or clockwise?
The impeller turns to the right and the flexible vanes bend to the left?
The closed-off keyway shaft opening is the top of the impeller and has to go up to get the impeller over the key?
I am sure this has been covered many times so please bare with me!
jtexas
Re: 78 70hp 3 cyl water pump
welcome to iboats!
The driveshaft always turns clockwise.
sorry, don't understand "closed-off keyway shaft opening...has to go up"
put the impeller on the driveshaft and slip the key into the driveshaft slot just before the impeller covers it.
A little grease in the housing and put it over the impeller, turn the driveshaft (clockwise) with your hand as you push the housing down - a good bit of force is required, but don't use any tools on it.
