Glastron Fisher
- Joined
- Dec 6, 2012
- 67
Ok so I had posted a thread about this motor befor and I have since solved original problem... Now il starting a new one with a few more issues. I had bought this motor needing a stator and dizzy belt, replaced the belt to see if it runs and have only gotten it to fire but not run. When I timed the dizzy I set the flywheel to the tdc mark and lined up the dizzy with a mark that was sticking out the side not an arrow on the dizzy. Now my issue is I cleaned the carbs to see if that was my problem but couldn't get any of the jets out so I just sprayed the crap out of it with cleaner. And I did a test showing my condenser is bad in the dizzy is that a part I can replace or is the whole dizzy bad? And can I temporarily bypass it to do more testing and getting the motor to run?
