'78 Ebko Lebaron - Therapy
  • Total voters
    13
  • Poll closed .
Trooper82
Checking in brutha Troop....
Lots'o work you've done my friend! I can almost smell the gel-coat! getting close dood!
Yo Bear!....thought I saw you lurking about these parts..thanks...yes lot's of work...and lots more to go...starting to zero in on the final fairing on the keel...then it will be gelling time...
Trooper82
Speaking of gelin'..taking a break and got time to post some thoughts...when it comes time to do the gell on the hull...got some questions...
1.How many coats am I going to need?
2. If more than 1 ( I assume 3 or 4) all wet on wet...not fully cured?
3. How the heck am I going to do that?
I can't reach the keel from the ground, so was thinking I will do what I can from above then down to ground to get the sides..but then I need to get back on top to do the other layers...if still wet that ain't gonna happen...
Just looking for some logistical advice...
sphelps
Does it have to be wet on wet ? Maybe some kind of temp scaffolding across the gantry . With no go go gadget arms not sure what you can do .. Someone will chime in with a good plan ..
jbcurt00
Did oops post details of how he shot the stretched hull? That was gel wasn't it? Or because the chine is likely to take some abuse, and is a 'hard' corner. Shoot chine to chine 1st in multiple coats, with the sides masked. Then shoot the sides multiple coats w/ the hull bottom masked. The chines get shot in both sessions.. May even be able to mask off in stages, shoot 1 coat, pull some masking, shoot a 2nd &, & , &..... Then the masked layers help feather the edge...... But that's all based on needing to do wet on wet coats..... And a best guess...
Carp........... DUDE just jumped from 128000+/- ft for RedBull.... CARP & just broke the sound barrier in freefall.... 729mph
Carp, wings, heck, HUGE stones too......
drexterm
great job on this project ........keep up the good work
Trooper82
Some progress today...but I grew tired of squating on the edge of the hull so calling it a day...
still going to need to do some more fairing it looks like...but it is getting close...
fat fanny
Troop a couple of 12' step ladders and 2 2x12 across the steps make for a good movable scaffold used this a few times painting my family room cieling (15' ceiling) just a thought. Hulls looking better each time I see it.
Trooper82
Thanks Fanny....it is starting to look like a boat again...I may have to do some sort of scaffolding..
Railcar
Whenever you do get it figured out, take some notes, My hull will be there next winter for fresh Gel.....lol. Looking good, cant wait to hear you splashed her.
fat fanny
Another thought would be a meg shift rotisary (bow eye, keyhole)
craigweaver
Looking good Troop. I about made myself crazy filling and fairing my hull. I finally had to say good enough and the fish would be the only ones to see it. I'll be watching and learning with you on the Gel coat process. I really think the cap on mine should be gel coated for the durability.
sphelps
Man that things in Vegas are sure it wont double for a slot machine !:D
jbcurt00
WOG, that's a fantastic looking machine:
It'll be $35-50 shipping, but if it'll sew multiple layers of marine vinyl it's worth the $. Who's the las vegas boater? He might grab it & ship it....
Trooper82
the hamsters actually ran that one past me....
Thanks CW...I am just about there.....deciding it is good enough...
This is a FANTASTIC Buy. Not sure what shipping would be but... GREAT machine. If you could get it to your house for under $175 it might be worth it.
http://lasvegas.craigslist.org/hsh/3311254915.html
I know some one in that area that might be able to ship it for me...will have to check into it....
Ebko gelcoat rotisary ! LMAO !!
I bet I could rig some ropes to hold it on one side then the next....
Trooper82
Didn't have much time with the boat tonight...just a little sanding.....
Decker83
The hull is looking fantastic. Looks better than new from the factory. What a tremendous amout of work you have put into it.
As far as the gel coat, you will need at least 2 coats. The 1st coat without any wax. The 2nd coat with the wax. You should spray the gel at least 30 mil to 35 mil thick. I think you need to let the 1st coat set up and then wait a few hours and shoot the next coat. As you know the gell without wax dosn't set hard like the resin so I don't think it makes a big differance in how long you wait to shoot the second coat so long as it dosn't try to sag on the 2nd coat.
I would think you are going to need some scaffolds setup. They need to be easy to get up and down on. Depending on what you use to spray the gel with, you will need to be able to clean the equipment quickly before the gel kicks. Put up some temporay sawhorse's with 2x12's so you can move them out of the way when you shoot the lower part of the hull.
Just my 2 cents...
Have a good week.
