'78 Ebko Lebaron - Therapy
  • Total voters
    13
  • Poll closed .
jbcurt00
looking like gelling weather...tomorrow...if it goes as planned....I will be using wax this go around....didn't have tome to get pva.....
Best of luck shooting the cap w/ gel this weekend!
Trooper82
Currently 64 degrees, but warming...getting things ready...need to make sure the hull is warmed up before spraying...I seem to have misplaced my wax percentage needed....still looking....
Edit: 2oz per gallon.....need to do the math to break it down to ml..
ok 2 oz per gallon = .5 oz per qt
.5 oz = 14.76 CC
I am going to be mixing 700ml of gel
750ml = .79 qts
.79 x .5 = .39 oz
.39 oz = 11.53 cc
soo.....
I'll be adding 11cc of wax on the last layer of gel....
D
Deleted member 340796
Guest
Captain I had the same problem yesterday and notified the administrator. So far so good today.
Troop, good luck with the gel and weather. Hope it is warm enough for you.
Trooper82
Thanks AJ, weather is warming up about right - 73 right now...but it is a little windy...and still have leaves falling....
jbcurt00
Gel or no gel?
Trooper82
Busy Saturday update.....
There was going to NO reusing the old acetone...
The Admiral and Jake were my only helpers today...Took plenty of video...but the camera was on low batteries so only got like the first minute or less...and the camera wasn't even on the action...doh!!
The Admiral...
And Jake...
There are 44 pics though...if you use your imagination...they are kinda like a moving picture show...not posting them all...but if you go to the Album Link in my sig, you can see them...
With the Admiral's help..got the masking paper all put on...started mixing and spraying...used 8 pails @ 750ml each..2 coats...last with wax added...Logistics of 2 coats..and getting in and out of the boat between them proved to be a bit of an issue...but a bucket on the sole made it a little easier getting in and out without touching anything...
Spraying...
Cleaning...
More Spraying...
GT1000000
Nice Job!
Once again you put us slackers to shame...what a machine!
Decker83
The cap looks great. Were you able to put more gel on this time.
I didn't try to spray today it was way to windy. Had to take down all the tarps before the wind tore them to peices.
Trooper82
Ya I did two coats, used waxl in second coat...forgot to get pva...just got back from checking....seems to be doing ok....couple small spots seem a bit tacky yet...hopefully they will cure by end of tomorrow...
Decker83
Hope it sets up for you. It should if the temps were over 70.
What did you keep your acetone in? Looks like it evaporated on you. Was it in a sealed container?
Trooper82
Bucket with a lid...it probaby did evaporate some...
Decker83
Didn't look in my bucket today, but I bet it did the same thing. Alot of wasted acetone. If I ever do this again I'm buying the gel dump gun.
