'78 Ebko Lebaron - Therapy
  • Total voters
    13
  • Poll closed .
tallcanadian
I will be posting some pics tomorrow. I'm in the process of glassing my stringers. OH WHAT JOY!! My motor painter is too fussy. He wants to repaint is because of a couple of tiny imperfections. I like it. I may have to tie him down..lol.
Trooper82
Almost finished with the first section on bottom so that leaves four sections total and the transon to do yet..just roughing...but the finishing goes quicker...I am beat think I am calling it a day...
GT1000000
You would be surprised to know that sanding is about 90% of every repair I do to a car...the other 10% is applying the bondo...and I don't even finish it...I leave it at 180 grit for the prep guy to take it to primer and 320 grit just before the painter gets it...
And yes, it takes an unbelievable amount of time to do just a small area... Just last week I finished doing the entire body on a 1976 Mini Cooper, and even though that thing is small, I spent close to 80 hours on it applying and sanding bondo...
Take a well deserved break, bro... we both deserve it!
Trooper82
Always teaching me something Gus, I saw you had said 1976 MiniCoper..thought it was a typo...who knew They started making Mini's in 1959?
I sure didn't!
I am officially working on the top four areas (as she sits) now :)
Pain in the butt...literally...
Trooper82
ok, just so I could liit the amount of time sitting up on the hull, I chose to use my random orbit sander...the bearing is shot so wasn't sure how long it would last...about 15 minutes...the little nylon cage that holds the bearings in place was gone...mostly...decided to make a replacement. Easiest way I could come up with was a piece of copper wire...that lasted about two uses of the sander. So I neeed something else..saw an empty bottle of MEKP and though, hey that is about the right diameter...Cut it off...shaped the bearing traps using the dremel...this lasted for about three uses...and kaboom..pieces and parts flying everywhere...gsthered them all up and decided to remake it a little better. Found an old metel broom handle about the right diameter...fit it to a wooden dowel to hold it while I worked on it. Center punched 9 equally spaced spots and drilled them out with the little drill press. Cut and ground the new cage to length while still on the dowel. Had to put the bearing back together. A little grease to hold the bearings in the outer race. Angle the inner race and flip it in place. Pushed in the new cage...marvelous! it works fairly well. Not too bad for a fix it your self job on a Sunday afternoon. filled with grease and am going to town with the sanding...
sphelps
That's what I call determination !!
I'm thinking a broken sander is a good reason to not get itchy ! :eyebrows:
Trooper82
Round one complete...and the repairs held up...off to round two....
Trooper82
Knockout in round 2 :(
Back to hand sanding for me...
tallcanadian
I think your addicted to sanding..lol. I don't envy you but the work will be worth it. The good thing is your arms should be huge by the time your done.
Trooper82
You know last week I picked up a sander, thought it was a variable speed random orbit...but it has no orbit function...decided to give it a try anyway...holy cow this thing knocks the high spots down quick...and has an attachment for the shopvac to boot!
Just set it to slow speed and keep it flat and moving...10 minutes on the transom and done..
Trooper82
OK, maybe only on large flat surfaces...and taking your time and paying attention to what you are doing....not for sitting on the hull when you are in a rush...
jbcurt00
Never seen that sander before, what's it's RPM's? I suspect even on low they're pretty high. So, yep, always moving!
Be careful, being non-random orbital, it can leave pretty good swirl scratches, that may be challenging to get out. What grit are you using on it?
Trooper82
Not sure of the rpm but it can go pretty slow...as long as I was careful it went ptretty good...started with 60 grit, got some 220 I may try tonight...
Trooper82
So the long weekend was good, made some decent progress on the sanding....
Paid for it in mighty sore arms though...so tonight I took it easy and finished the transom skin...and I am pretty happy with it this time around...
I notice however that the shine when looking directly into the surface is rather lacking...kinda blotchy even...
Could it be the compound I am using? This is what I am using... the stuff is probably 10 years old...I got medium fine and Black Cherry Glaze...I tried the glaze before and did not like the black greasy look it left behind. The medium and fine is a sort of wax base...I use small amounts and it takes awhile before it is finished cutting..or sticking which ever it is doing. the el cheapo bonnet I got from HF is almost toast...
So my question...is copmound just compound or is there different types for paint vs. gelcoat?
Short week, come on Friday!
GT1000000
Old compound could be part of the problem as the liquid type ingredients used in making the stuff may have evaporated...
Good quality bonnets do make a big difference as to the quality of the "cut"
I don't mean this to sound like a paid advertisement for 3M products, but at the shop, we use them on Brand new $80K+ vehicles from the dealer and they constantly compliment us that when they get cars back from us, they look better than from the factory...
Yes, a lot of it has to do with the detailer's experience, but both he and the painter swear by these products and both have tried several different brands...
That is not to say that there aren't other brands that are equal to or even better, but these are tried and true at the shop...
Check this out... Compounds, Polishes, Glazes, Perfect-it, Compounding, Polishing, Glazing, Paint Finishing, Rubbing Compound, Buffing Compound
No matter what, you are getting it to look pretty amazing, nice job!:)
Trooper82
Thanks Gus..I will do some reading....the stuff zi had is what the admiral used on paint way back when...
