'78 Ebko Lebaron - Therapy
  • Total voters
    13
  • Poll closed .
fat fanny
I'm with zool looks like a scaraab. Man that rig sure looks different from when you started! I remember it well your hard work is showing with every step.Keep on keepin on Troop
sphelps
Nice job on the reflip Troop ! I almost forgot how sleek looking the hull was ! Looking forward to the next phase !
Trooper82
Thank you all for the good thoughts, things went as well as they could have...
May be a bit slow for a boat update...found an old Rockwell 34-410 Table saw on CL I couldn't pass on...giving it a little tlc...
Trooper82
Time to crack this thing open...
I recall that I was in a hurry when I put the cap on, so going to pull it and do it right...
GT1000000
That table saw sounds like a real nice piece...is it a commercial type machine...?
And I can only imagine that you had put the cap on just for the move, but still had some things to finish up under it?
GT1000000
Oops!, never mind, I forgot I have the internet...I looked up the table saw...
NICE!
10" Contractors Model...
Trooper82
It is just an older cast iron topped tablesaw...not the big heavy duty oner they make...but it will work for me just fine....
Yes I pretty much just threw it on knowing I needed it on to haul....I'll get it like I want soon enough..
sphelps
Sweet score on the table saw ! Mine is a piece of carp . I need an upgrade .. :facepalm:
Decker83
That's a real nice table saw.. Great brand name.. If the rip fence is the same as in the pic, it will be a great addition to the garage..:applause:
Trooper82
Got the saw parts in primer...
Even though the spraying(HLVP) went very well (added acetone till is was pretty thin)....I noticed that the primer I picked up in a certian tractor store...had about 1/2" of gunk in the bottom of the qt can...I mixed it with a drill for 5 minutes or so before pouring into a container to add the acetone....the stuff hasn't been on the shelf any longer than I have been in PA...
Guess you need to put a stick in the bottom and check it before using?
tallcanadian
Of course. It isn't bad enough that you do awesome quality work on your boat, but I guess you can't do that with a dirty old saw..:facepalm::D. Just pickin on ya. That old saw is just going to look just as great as the boat. Nice score on it.
jbcurt00
Nice work spraying the saw parts, I don't know about the gunk, but I reckon it isn't supposed to be there..
Trooper82
Just got a call from WoG...sounds like my primer may have seperated...waiting fir the 24 hrs to test it....if it doesn't produce powder when sanded....it will have to come off...crossing my fingers...
EDIT: Just got back in from checking...primer seems to be setting up....and sandable in the spot I checked
GT1000000
Most good primers have a lot of solids in them to help fill minor imperfections...
Like most good quality paints, when they sit for extended periods of time, the solids tend to separate out and settle to the bottom...
A good stirring is usually sufficient to bring them back to life...I have even stirred thoroughly once, let it sit for about 1/2 an hour and stir again to make sure I got everything distributed evenly...
You could put your saw in the place I found the pic of yours as another oldie, but goodie brought back to life...
Photo Index - Rockwell Manufacturing Co. - model 10 contractors saw 34-410 | VintageMachinery.org
Woodonglass
Note about Majic Primer. I spoke with the lead tech a Majic for over an hour several months ago when Decker was having issues with his primer on his trailer. I was told by the tech that once the solids in the Majic primer separate and settle they will not molecularly re-bond with the solution and the primer is pretty much worthless. If you buy majic primer you should open it at the store and ensure the solids are not at the bottom of the can. This came straight from Majic.
I told Trooper that his Rockwell saw was the saw I used when I was a contractor back in the 80's. It made me a Lot of money and was a great saw.
