'78 Ebko Lebaron - Therapy
  • Total voters
    13
  • Poll closed .
Decker83
Really nice work on the tables..
JB, I have used the Skill tools before and they worked fine for me..
Nice looking set of bits too..:joyous:
bajaunderground
Hey...what's with all the distraction? 2+ pages of table saw stuff...while I can appreciate such a nice TB (BTW, that's a really cool one, you did an outstanding job refurbing it...those table are awesome too, clearly skilled, you should use that to re-do a boat....wait...). I understand you have other things to do...but lets get back with the boat already!
"we interrupt this boat build to bring you a life!
Of course I'm joking (see below, second part of signature)
~Brett
Zyen
hey troy! first...thank you for your service.
now, im guessing that seeing woody making things outta wood got you jealous, so you had to make things, too??? :D
tables look great. nice job.
Trooper82
Thanks Kent, Brett and Allen...
Boat work coming soon...getting close to the anniversary....
But for now I got some stain and the Admiral's tables....used a rag yesterday for the first coat, tried a brush on second coat after some light steel wool...think I need to scrub them one more time to get rid of the runs and darker areas...
Went out to the garage to get my camera, was surprised to see it was a warm 54 degrees inside....no heat since Sunday...temps outside been below 30 last couple of days...very happy I invested in the new walls...
zool
I guess because it was "The Admirals" table, you were allowed to stain in the house? heh
I like the rag method myself, it takes more coats, but i seem to get more blotches with a brush, foam or not..even brushing into the wet edge....seems like you get more control rubbing it in.
Looks good :)
sphelps
Looks great ! For a sealer you might consider using some tung oil . Really easy to apply . But there may be better products . IDK .
Trooper82
I have used tongue oil before on a rifle stock I made...all hand rubbed dark american walnut, turned out great! But that took many hours ...would take months doing a table, no less two of em :(
Looks good :)
Yes Zool and it was her idea!
jbcurt00
Stain color on the table looks great, i too prefer wipe on wipe off staining...
Trooper82
So I am looking to you all for some advice...as you may recall when I out the gel down on the deck I used wax in the mix and rolled it out with a paint roller...it neve really cured like it should have...since then it has collected dirt and dust form the travels and all the sanding i have done...the other day I took a rag withacetone and wiped an area down to see if I could clean it up...the gel got very soft while wet with the acetone, while alot of dirt came off, alot stayed...so after it dried. I took a sander to it...looks better but still dirt in the low parts...
So the qeustion...do I start sanding down past the dirt and muck, then a new layer of csm followed by a proper gel coat spray then pva on the gel to cure? Or can i just put a layer of csm down over the dirt then gel?
jbcurt00
This for sure
What's your reasoning for more CSM?
This sounds good too
Yeah, probably not a good idea.
But what do I know,:confused: apparently, I'm a tinfoil hat wearing kinda guy.... :tinfoil3: :facepalm:
bajaunderground
I have nothing constructive to add to the "process" of gel coating, except...you've come this far and done a ton of work on her...best to take the add'l time to make her look as good as you're capable of...which looking thru your re-build is nothing less than "better than new"...whatever process that involves...you're in the home stretch. We're cheering for you!
~Brett
sphelps
Yep ' no expert but would think sanding till dirt it gone . I used the gell with wax so I had to sand between coats . Still need to seal it though . Maybe you were thinking a different type tung oil . This is what I used on my dining room table and chairs . Super easy and dries fast..
Minwax 1-qt. Tung Oil Finish-67500 at The Home Depot
Decker83
From what I have read and what little experience I have, it sounds like the gel did not cure properly on the surface..
From what I understand the gel coat will cure under the top coat of gel without wax.. That's what sounds like is happening to your gel coat..
I would use the acetone to remove as much as possible and the sand it down untill you reach the harder gel coat..
Then acetone again and do the new spray..
Don't think you need to try new csm over the gel coat.. It may not bond to it..
Just my thoughts on this..
The table looks great with the stain.. Amazing what the old shelves turned into..
Good luck on the gel coat..
Trooper82
Thanks for the advice all...once again just confirms what I already figured was to be the plan...think i will use buckets of soapy water while sanding...hope it helps with the stickyness on the sanding pads....
the reason i was thinking maybe a. New layer of csm was that it would hold better than just gel over a dirty surface.....but i gues there is no substitute for good prep...
Decker83
The stickyness is the uncured gel.. Try to remove as much as you can with a soaked acetone rag in small areas at a time.
It will help with the sticky sanding..
I had to do it on my first boat I did with gel.. Didn't known about the wax or pva when I sprayed it.. I just used the acetone and rag then sanded..
Trooper82
Decker..you got it right....very small areas..
The center of this pic was plain acetone...to the right I had done acetone followed by a sanding...the dirt creeped in still looks like to me
Close up of that area I did last week....acetone then sanding...
going to take a lot of rags...the dirt smears if you don't freshen the rag...
Decker83
Looks like you got it going your way..:joyous:
Woodonglass
Troop, One things for sure, Properly cured gelcoat should not be softened to the point of eating it away by acetone. If it does then you got a major problem and IMHO it should be removed and replaced. I'm not exactly sure why it occured but a properly mixed ratio of gelcoat, mekp, and wax should cure to a rock hard consistency and not be negatively affected by acetone.
Trooper82
I agree wood...this was my first large are putting gel dow, if I recall correctly it may have been raing or very humid when I rolled it too...will take some work, but I'll get it fixed...come on weekend!
Pmccraney
Sorry for the setback on your gelly coat, troop... You will get it right. Nice job on those tables btw.
