Bosunsmate
- Joined
- Apr 7, 2012
- 6,135
I was testing whether it was firing or not by pulling off the plug wires while running. Also, when you say, “Your cylinders are sounding pretty bad”, are you implying they should have much more compression, I’m assuming? Thanks!
Singularly not plural- i shouldnt of added an S to cylinder. Just the one cylinder isnt looking so hot.
But i agree with Harrington, 103PSI is more than enough to make it fire. I suggest you find out why it isnt before you tear it down.
Ive had motors work on low compression on one cylinder for a long time. The gouges get carbon in them and things can settle down for a long time. So if you are like me and every penny counts then thats what i would be doing, ideally you should be looking to rebuild but Macgyver wouldnt and he gets by
