harrylarson
Thread starter- Joined
- May 7, 2011
- 27
Hello, if anyone could help or clarify. I bought a '78, 150 hp Johnson. Hasn't ran for at least 4 years. I did a compression check and found #1 100psi, #2 90 psi, #3 60si, and the rest right at 100psi. I understand from reading a bit that the next move would be to remove at least the one head(right bank) and check out the #3 cylinder for damage. probably the left head to.
I want to know what exactly I'm looking for, and would there be anything I might find that could be fixed to get the compression back where it should be without a complete rebuild.
I bought this motor for $300 with the understanding that it would probably need a rebuild, I just want to clarify that removing the head or heads is the next move and just what I'm looking for. Thanks.
