I have a 1978 70hp Johnson that I had carbs rebuilt last year along with a new fuel pump kit. I went to put it in the water and it wouldn't idle unless I had it choked. When I'd put it in gear or would try to rev it up it would die. So I put in new plugs and put it back in the water this time it started up fine idled fine, no choke, reved up fine, but as soon as I put it in gear it would die. I even got my brother to hold the idle up manually as I put it into gear. No luck. So we pulled it out of the water started it up put it into gear and it worked fine so we left it in gear about half throttle and as soon as the motor went under it would bog down and die. We did this several times with the same results. So if anyone can help me I'd appreciate it.
