Figured I would try a new post..and add pics.
Story goes like this..... lost my keys and replaced igntion switch. When I turn the key the motor wont start. However, when the key is in the on position I can jump the motor and it runs fine. Then when I use the key to turn off the motor it turns off. I have checked 3-4 times to make sure the wires are correct to the switch before closing up the remote control. Any ideas or comments would be most appreciated.
UPDATE:
OK.... I received some advice to check the inline fuse. I did replace the fuse in #4 now the "electric" choke engages. This is a step in the right direction. Now, I did check the neutral switch (inside the remote).... I can attest that it does engage and click in place. I have checked all my wires and connections:
1. Ground is connected
2. Starter is connected
3. Harness is connected
4. Inline fuse is connected and good
5. Battery is connected to bottom solenoid contact.
At this point I am curious what the 2 wires are coming out from the remote control unit:
The grey one goes into the harness, the red one goes into the control unit. I was assuming it was for a tach? Thanks for any extra help guys.
UPDATE:
