78 Mercury 90hp Inline 6 carb. issue
Gomer50
I ran my fresh Mercury rebuilt 1978 inline 6 this weekend and ran very nice except I used a lot of fuel 6 gallons in 1 1/2 hour. Throttling up and down cruising at various rpm's to break it in. I noticed that the carb. linkage that connects carb.1 to carb.2 and carb.3 are soaked with fuel. Which leads me to believe there is way to much gas in the carb throats.Carbs are not leaking anywhere else.Any Ideas on what causes this problem.
Gomer50
Re: 78 Mercury 90hp Inline 6 carb. issue
Link and sync was done.I am pretty satisfied with the performance results, this motor sits on the back of a 1972 15 foot starcraft trihull weighing 1100 lbs, motor 300 lbs, humans 500 lbs and other junk. So I would say around 2000 lbs. 13 1/4 17 pitch SS prop turning @ WOT 5000 RPM and 36 MPH by GPS isnt too bad.
Gomer50
Carb. linkage that connects carb.1 to carb.2 and carb.3 are still leaking gas. Which leads me to believe there is still way to much gas in the carb throats.Carbs are not leaking anywhere else.Any Ideas on what causes this problem.
Bob_VT
You are not hitting WOT ...... you should be turning 5500-5800 with that motor. Are you sure the butterfly's are opening all the way, is the tach accurate? you might be better off moving to a 15" pitch prop. Is the gas leaking out of the linkage shaft ???
Gomer50
Yes the gas is leaking out of the linkage shaft (s). I have been speaking with a gentleman thats been dealing with Older Mercs. for a long time and he mentioned that the back draft carbs were a bad design and were frequently known as piston eaters. He suggested that I plug off the little hose outlets/inlets.It was also mentioned that when priming with the bulb the bulb can push in upwards of 16 psi of fuel pressure which will push excess gas into the carb throat and of course drible down the linkage.So all in all I think I will take these carbs back off and put on an older set without the back draft with one size larger jet. Suggested by an old Merc. guru.
Bob_VT
Yes a good old BB blocks that line just perfect. It was an economy thing that Merc designed in and best blocked off.
Moody Blue
Out of curiosity, when were the backdraft carbs introduced, and how long were they in production? Were they used on all the in-lines or specific models?
Gomer50
The first back draft carbs I have seen were on a 1974 85hp inline 4 and I also have 1978 90hp inline 6 that have the same ones.I have also seen these on a 1980 inline 6 115hp as well.
M
Maxz695
Guest
remind me not to ever buy one of these thanks
Chris1956
Honorary Supreme Mariner
Wide open specs for that motor would be 9 gal/hour, so your fuel consumption is pretty normal. Try a V6 motor sometime. They have 3 two bbl carbs and can really suck up some fuel!
I ran wide open in my speedboat with a Merc 1500 inline six. Used 6 gal fuel in 20 min, but covered nearly 20 miles.
I recommend you check your carb float heights. Sounds like you have a small overflow, into the venturies.
BTW - Don't worry about the backdraft carbs. They will work just fine, as long an they are kept clean. Just like any other carbs.
