poppasmurff
Thread starter- Joined
- Jul 13, 2008
- 39
Ok heres the scoop. I recently bought a '78 cobia w/120 GMC and a 400 OMC outdrive. I purchased this boat from an elrly gentelman who would only go out once in a while to tool around to his fishing spots on the river behind his house. He had pulled the originale fuel tank and replaced it with a 5gal john-boat tank, it seamed to work but 5 gal was kinda small for me so I replaced it with an 18 gal fuel tank. I have since found out that my distributer shaft has lateral play and to try and adjust the points is immpossible . When I got the boat it started on the first try and ran ok but seemed to be lacking in RPM at WOT.(3600-3800), and now the boat won't even start...it will fire but run rough and stalls right away. Is this consistant with the points/distributor issue? We were out on the boat a week ago and were enjoying the day when it seemed to run outta fuel. I checked and fuel tank not empty but boat would not re-start.....killed the starter. this issue is plaging me now. HELP!!!
