78 TO 82 115HP CARBURETOR SWAP??
phx5kegsman
Will the carbs off of a 1982 Evinrude 115 work on a 1978 Johnson 115?
Honorary Supreme Mariner
Are there choke plates in the 1982 model carburetors?-------There are in the 78 model.-----So you would also need the electric primer valve.
phx5kegsman
I have the electric primer valve. Can I convert my choke solenoid type to the primer type? (Actually, I have been wanting to do away with the choke solenoid setup. The plastic clip on the end of the plunger was brittle and snapped in half. I repaired it with epoxy, but I think that made it too heavy. Sometimes I have to pull the top cover off and manually choke to start. A real pita. I haven't been able to find a replacement part for it) Didn't want to mess with it until I had to, but my carbs definitely need some attention. After a day out on the water I can see fuel seeping through the bowl gaskets!
saltchuckmatt
I take it you have a parts motor. Take a look how they plumb the primer...is their one tube to the carb and one to the intake? You might have to pull the intake too.
phx5kegsman
Yes. the tubes go to intake and carbs. I've decided to just pull the carbs off the 78 and rebuild. The 82 isn't necessarily a "parts motor"...more like a "spare motor" that I plan on using if/when the rings break on the 78. I should probably not start picking parts off of it and keep it complete
saltchuckmatt
Good plan!
flyingscott
Aren't those different blocks? I thought the 99 cid block came out in 79? 93 cid blocks were 78 and before.
Nope-----99 cube blocks for the 1973 and newer115 HP.-----The 85 HP had less displacement up to and including 1978!!------In 79 the the 85 also had the 99 cubes.
