Re: 78Johnson 70 wont idle, hard to start
Hard to start cold, warm or both?
You just acquired this motor, and been like this since you got it?
Engine not running, air silencer cover off, motor tilted full up, pump up the primer bulb -- if gas comes out the carb throats, your float valves are shot and need replacing, they're flooding the motor at low RPMs.
Either way, dry or flooded, carb rebuild is the answer. These carbs are remarkably simple devices, don't be intimidated.
You should be running Champion QL77JC4 plugs gapped at .030.
If you don't know how old the water pump impeller is, or if it's more than 2 years, plan on replacing it at your next available opportunity.
I'm guessing from your screen name that motor is installed on a 1978 Terry tri-hull bass boat -- am I close?
