79’ Evinrude 70 Bogging
jpjourdonnais
I have a 1979 Evinrude 70 (70973R) when I put it in gear and give it throttle, it’s tends to bog down and die, after some finesse with the throttle I can get past it and it runs amazing at WOT. The other thing I noticed is it doesn’t like to idle at low RPM, it takes about 1200-1300 RPM in neutral in the water to keep It running while in gear in the water, if I put it in gear with the idle adjusted any lower, it dies. I’d like to try and get a lower neutral ideally because it shifts really hard at that RPM. It runs great on muffs. I’ve tried choking it and pumping the primer bulb when it stumbles and it makes no difference. It has a 13.75/15 prop on it that’s had the vents added per the OMC SB. It has new ignition coils, a new power pack, new spark plugs, new fuel lines, a good primer bulb. And the carbs have been cleaned recently.
Honorary Supreme Mariner
You start with a compression test.----Post the actual values you get on this 45 year old fine ( when new ) motor.
Fuel pump diaphragm checked?----Reed valves checked ?-----Flywheel key checked ?----Perhaps throttle plates are opening too early.
Crosbyman
carbs cleaned recently... do you mean removed, orifices cleaned out float checked out etc...
these are old style carbs easy to clean up incl.. side channel for LS upper drip chamber under the die size plug which feeds fuel for idling properly .
jimmbo
Fuel pump seems okay, the diaphragm isn’t stiff or broken.
How do I check the flywheel key, and if the throttle plates are opening and too soon?
It is easy to see if the Throttle Valves are fully open, by looking down the Carb Throat.
A check of the Link and Sync will verify proper Carb Opening, in relation to Spark Advance. That needs to be checked and if needed, adjusted any time a Carb is taken off.
jpjourdonnais
The carbs were completely rebuilt by a local shop. In addition I cleaned them all myself, including running a single strand wire through all the jets. The carbs are spotless.
Throttle valves fully open in sync. And are synced when at idle as well. I’ll run through the procedure again.
A took it out a ran it to get a gauge of where it’s at now, and the bogging during acceleration only comes after long periods of idling. At idle in gear, it starts out around 1000rpm and slowly loses RPM over the course of a minute or two until it gets to about the mid 700s. Then it starts to stall out and die. But what i found is if I do a quick bump of the choke during that period after it hits the mid 700s to when it fully stalls, it recovers itself back to the 1000rpm and the process repeats. If I bump the choke too early, it causes it to die. (This is a new symptom)
Mind you when I say bump the choke, it’s quite literally just a quick tap of the key button.
If I bring it out of the idle detent and throttle it up to about 1200-1500 rpm, it’ll go all day long. Same with at any RPM above that.
Crosbyman
recheck the fuel pump operation especially the pulse hose for air airs due to cracks or loose clips. you checked the diaphragm but actual pump operation can only be confirmed by measuring fuel pressure output to carbs....something I have never done mind you. FP are not terribly expensive and may be an option to consider.
here is a copy cat (I know it is not OEM...) but some comments are very good ...
Verified Purchase
I used this pump to replace a broken VRO fuel pump on a 70 hp VRO Johnson outboard. The previous VRO pump was putting out virtually no gas at an idle. The new pump discharged approximately 2 cups of gas per minute at an idle. This was more than I expected and it completely solve the pump issue with the motor.
sounds like a carb issue. if the fuel pump was dying, its rare to have it only fail at slow speed but be unaffected in its function at higher speeds. to test this, remove air silencer cover and squirt a little premix into each carb throat when it starts dying. that way you can isolate which idle circuit/carb is blocked. did you squirt carb cleaner up the idle pickup tube and watch it spray out the tiny holes in the roof of the carb? do the same down the slow speed/idle orifice channel behind the flathead screw in the front of the carbs. must be clear. lastly blow through the fuel inlet with carb upside down . shouldnt be able to blow any air through. if you can needle is leaking. floats are set just a hair up from level to carb body, but level would be acceptable as well.
Crosbyman
It does seem OP had the carb work done in post #10 in theory eliminating that option & leading to a possible pump problem...... my thinking being that at higher RPMs the pump is getting a lot more pressure pulses from the crankcase to have it pull in more fuel for distribution to the carbs.
some soapy water spray may flag pressure pulses leaking at the engine block or pump pulse connection causing a weak pump operation.
jpjourdonnais
Just replaced the fuel pump with a new one today. Just in case there was a pin hole leak somewhere that I couldn’t see. Going to run it today or tomorrow and will advise. I’ll bring a soapy water spray as well.
jpjourdonnais
boat ran great overall, and seems a bit better but that might just be the placebo effect. No leaks on any of the fuel lines or crankcase line going to the fuel pump. I think it’s running just a bit lean, and I’m going to try and replace the size 35 off idle/fuel mix jets with size 40. I’ll keep you guys posted.
how are you determining its running lean? a few drops of fuel into each carb throat. if it picks up rpm, its running lean. if its sneezing, those carb plates might be stuck open a hair or the spring for the throttle shaft isnt wrapped around it to put tension on them.
jpjourdonnais
Wasn’t Sneezing. see post #10 for symptoms.
But after replacing the off-idle jets with size 40, it runs perfect. I’m going to try 38s to see how it does also.
Crosbyman
sounds mysterious that you would need to increment the jet size after all these years unless a big altitude change took place. but if it works great !!
