79 115hp mercury inline 6
spaceghost
i have 125compression on 5 out of 6 cylinders, one is at 25, is this motor still operational? could it just be theres something stuck in that one cylinder? motor hasnt been run for 3yrs. maybe just needs cleaned good?
spaceghost
Re: 79 115hp mercury inline 6
hey also, can the trim/tilt motor be rebuilt. It only raises the motor half way up then drops. so i assume the motors good. maybe just air in the lines? thanks
Clams Canino
(I accidentally replied to the duplicate thread) I moved my answer to the real thread. :) <br /><br />-W
eltzholtz2
no you should'nt run like that and probably needs alot more than cleaned out
emckelvy
She's a Goner. Lemme guess, low compression in either #1 or #3. At least, those are the more common cyl's to fail on the old Inlines.
Time to tear down and assess the damage. Guaranteed fried piston, if you're lucky you won't have to bore the cyl out; but the teardown will tell all.
G'luck............ed
AMD Rules
Why reply to a 2 year old post?
emckelvy
Well, I guess it's still Toast! Actually, didn't notice the date.:$
