Menace2Authority
Thread starter- Joined
- Jun 11, 2010
- 38
I've made a couple other posts on my "issues" however as symptoms have become more clear I figured I'd start another post.
1979 Mercruiser 165hp in line 6 cyl.
Initially, the boat seemed to be stalling and not re-starting once it got warm. So this morning I bought a new coil for it. Fired it up and let it idle at the dock for about 20 min. Rev'd it up to about 3000 rpm with the engine good and warm and it didn't stall. So I assumed I may have fixed the problem. Later in the day I decided to test drive the boat around in front of the dock. Putted around a bit very slowly with no problems. Gave the boat about 3/4 throttle and about 2 seconds after it planed out it stalled. Again.... it wouldn't start. It would fire and briefly sputter, but would not stay running. Within 5 minutes of it stalling I was back at the dock thanks to a nice fellow boater who towed me. As soon as I tied off, I gave the boat some throttle, turned the key and it fired right up and idled nicely for 15 min or so. At that point I again gave it throttle in "neutral" and still it ran fine. I shut the motor off and with it hot I did a compression test and compression was 120 across the board (give or take a couple pounds).
When the boat stalls it feels as though it's running out of gas with a few caughs/chugs before dying.
So....
-Engine stalling under a load. Running fine in neutral
-Starts real good
-Good compression when warm
-New Coil
-Plugs all look good
-Full tank of new gas and the "pump ball" on the fuel line is hard so there's good fuel flow at least to that point.
-Boat won't run long enough in gear to over heat it and in neutral has only gotten to about 145 degrees.
Any ideas? I'm stumped here and even the couple mechanic friends I have are having a hard time offering advice.
Thanks,
Rob
So....
-Starts real good
-New Coil
Thanks,
Rob
