trivenbark
Thread starter- Joined
- Mar 27, 2009
- 3
i want to see if anyone can help me . okay to start off this engine was running fine then started acting up then shut off. then when i got it home got my tinkerbug neighbor who works on small engines (lawnmowers and such) and around 65 so we tried to start it would not start after about20-30 pulls he suggusted we use some other parts from my spare motor when he breakloose abolt from powerpak it backfired. then he said there is a ground problem.then we cleaned every ground on motor (coils-straps etc.) then we pulled cord not even half out started right up.okay let it run 10-15 minetes.then took back to water went about 300 ft shut off again. now we have changed coils stater-power pak and flywheel and only the bottom cylinder has fire.we took the pins for the 3 wire plug for coils out of plug and the only fire is in the center and unplgged killswitchand when you move top coil wire to center hole it will fire then something is stopping top coil from firing? any help would be very kind thanks thomas oh almost forgot this motor is all manual thanks
