Mrcleaningguys
Thread starter- Joined
- Aug 7, 2015
- 46
Boat thought it was a submarine. Outboard went under. Rescued her. Then began the long, painful, expensive lesson getting her back to working order.
During this month long maintenance and restoration process, I noticed oil/water leaking from the propeller area. Not a lot but enough to cause concern. I drained it and got oil (no noticeable water).
Just to be safe, I called the marina to inquire about lower unit seals, and was sold a single seal. I also bought a manual and it appears there are actually 2 seals back to back. He never mentioned the 2nd one......so my question is.......
Do I have to replace both or would replacing the top (outer) seal do the trick? Is it possible the oil and water mixed simply because of the motor capsizing or should the seal (seals) definitely be replaced? Also is it possible that this seal doesn't even go to the prop shaft but rather goes underneath the impeller housing?
Thanks in advance for any advice or input.
