Hi,
I just purchased a 1979 Evinrude 115 and am having trouble getting both forward and reverse at the same time. I’m able to adjust the cable and get either forward or reverse but can’t get both. I’m using the control box from my old outboard which was a 1978 Evinrude 70hp. I did notice that the control box is different between the two but I’m not sure if it’s the control box that isn’t allowing enough movement in the cables to select both or if it’s actually a problem in the lower unit.. I’m thinking I may need to buy a new control box to suit the 115 but I’m not 100% sure if that’s the case. Any advice would be appreciated.
Regards,
James.
EDIT
I have attached a diagram of the 70hp control box that I’m using so you can see which box it is.
Regards,
James.
EDIT
