ponyboy1995
Thread starter- Joined
- May 30, 2012
- 6
Hello, I am new to the forums here. As stated above, I have a 1979 85hp Evinrude that was running great until this weekend.
After running good for about a 1/2 hour on and off the motor started idling very high.
It started idling around 4k rpm. I took the motor cover off and realized that the throttle linkage was not returning to the normal idle
Position. When I lift the warm up / starting lever then lower the lever back down the linkage never returns to normal idle.
The only thing that has was different from prior use is that the rubber piece that goes around the cables that stops water from entering
The engine compartment came loose and fell out. I put it back in when i was getting the boat ready for summer. After this started I pulled it back out to see if that had something to do with it, but it still does it. Any help would be greatly appreciated.
Thanks, Joe
Thanks, Joe
