I'm trying to remove the powerhead from a 79 Johnson 15 HP. I've removed the 6 bolts that connect the powerhead to the outer exhaust housing and the 3 bolts that mount the lower motor cover to the powerhead. The powerhead doesn't want to budge. It may be just gasket sealer that is holding it down, but before I use too much force, I want to make sure that I haven't missed anything. Looking at the parts diagram, it looks like the inner exhaust housing is bolted directly to the powerhead and so will need to come up with it.
