imported_doc
Thread starter- Joined
- Jul 9, 2006
- 4
79 johnson 15hp will hit and run a few seconds if sprayed in bottom cylinder with ether. this won't
work on the top cylinder. it has good fire although
i have trouble telling the difference in fire and hot fire.
compression and fuel system seem ok. flywheel key ok
plugs new. apparently timing is ok at least on the bottom
cylinder. any suggestions welcome.
