79 Merc 150 engine problem
gonzz
I was out today and noticed when i gave it throttle it was like a clutch was engaging and the boat would not go anywhere. Like a bearing is spinning durig throttle. What could this be?
Barnacle_Bill
Re: 79 Merc 150 engine problem
Are you saying the motor revs up but you don't go faster?
gonzz
Yes. It's like I am pushing in a clutch pedal. You can hear the RPM increase but that's it.
RadarRick
The prop could be spinning on the rubber hub. If so, you can get it repaired at a prop shop.
gonzz
How much does the repair cost?
ONERCBOATER
locally here at least they want $80 to replace hub..... and online i can buy an aluminum prop for $91- 130 including shipping.....
call your local shop and find out ;)
gonzz
I took some pics after I took the prop off. The prop nut wasn't on that tight when i went to remove it. It was a self locking nut. Is this a 1 piece hub/prop or do I have to get the hub pressed off?
SparkieBoat
it has to be pressed on and off..you have to take it to a prop shop.
RadarRick
Make a mark accross the hub and the prop spindle, then go out and use it again. Afterwards, if the marks no longer line up - you have confirmation that the hub has spun.
