79 Mercruiser-120 No spark
Will Brad
Changed coil, points, condensor. Put in new plugs. Has power to coil. Won't start. Started before. Removed engine, changed freeze plug. Put in new plugs. Still nothing. It just cranks. Looking for a different wiring diag. then the one in seloc?
uaw9fan
Re: 79 Mercruiser-120 No spark
Have you disconnected the shift interrupt switch to verify there is no problem in that area.
chiefalen
You pulled a plug and cranked it while grounding the plug no spark?
If yes, points to wide?
Condenser could be bad from brand new.
Wires clean all around, grounds also.
Dizzy cap clean inside good connection of rotor.
Plug wires good, one from coil to dizzy good?
Ayuh,....
Did you properly Set the Points,..??
Did you set the Dwell,..??
Did you reset the Timing,..??
Is there power to the hot side of the Points,..??
Will Brad
To all the people who gave suggestions, finally deciced to purchase a new starter, (stopped cranking). Installed starter and what do you know, it started right up. Thanks for all the help.
:rolleyes:
Don S
Obviously, it was cranking so slow with that bad starter that it wouldn't start.
You do have to get enough rpm while cranking for the engine to actually start and run.
chiefalen
Stupid me and i thought he had no spark. I didn't see nothing about a slow cranking starter.
Ayuh,...
He never said he did,... Only power To the coil....
Bt Doctur
If the solenoid supplies power during cranking ,I guess it could short out and provide no power for spark
