Re: '79 Starcraft SS 16 restoration
Spent some time yesterday and on friday working on the transom and splashwell.
The dry fitting is not going so well, there are a couple areas where the width is tight. I bought a couple grinding stones and took off a stubborn layer of foam/seal stuff off the inside edge of the splashwell, hoping the two pieces would slide into place easier.
Not the case. There's a spot on either side where the splashwell attaches that juts out and is making this a bit of a pain.
Not sure if it's been bent or what. I'm now wishing that I'd removed the entire splashwell, but I didn't because this way is easier:facepalm:
I'm gonna sand down the ply in that spot so it fits, and keep moving forward hopefully.
Hoping to get the wood drilled and epoxied this week. Then it's back into teardown phase, all wiring, consoles, windshield and bow structure is gonna be removed again so I can finish the interior finally.
No leads on a new motor yet, and part of the motor budget went into a 2009 Ford Flex. The transmision on our van went out right when we were heading 4hrs north last week, and I wanted to have a back-up tow vehicle rather than a mini-van anyhow.
It's rated for 4500lbs and I'm getting a full-size hitch installed once the snow melts. Anyone know when that's supposed to happen?
