Huron Angler
- Joined
- Apr 7, 2009
- 6,025
Re: '79 Starcraft SS 16 restoration
I spent the day removing old deck rivets, old vinyl and cleaning up the interior of the hull a bit.
One question...How do you remove a rivet that is on a rib without having the end fall down and stay inside the rib? In some cases I can use an extendable magnetic reacher tool, some have little access.
I've had great luck drilling the heads out while holding the ends with pliers, but in the ribs obviously no access the the end. Here's a photo of one I need to remove.
She's looking a little cleaner
Should I be removing these aluminum supports just to get this old vinyl out of there?
It seems like it would be ok to just leave the vinyl there...and if I did remove it could possibly loosen and wiggle a bit? The supports are what the bow bench seating platform is riveted to.
I've just been yanking it out with my trusty needlenose pliers, leaving the lovely vinyl adhesive residue underneath that I'll be taking a sanding disk to as Pualy recommended.
