- Joined
- Apr 17, 2002
- 71,464
Ayuh,..... A 26 year old boat ain't brand new,.....It's brand new.
You have corroded connections,..... Somewhere,.....
with 2024 boats coming out, your 1997 boat is 27 years old.It's brand new.
The ignition sensor*Ayuh,..... A 26 year old boat ain't brand new,.....
Hey man, this is a different boat, not mine, but a client's. It is a 1997 WellCraft with a 5.7 2 BBL Mercarb. The ignition is Thunderbolt V.Drew, Is yours a TB 4 or TB5? I have diagrams for both (and the shop manual for the 92-98 big block engines if you need it), if you need them
Check
1. The big round plug that connects the engine harness to the boat for tightness / corrosion on the pins. (Had to replace the one I had on my 2550 SX)
2. Ignition switch / wiring for same and if the switch is good. See if you have 12 volts coming out of it.
3. Engine ground to batteries.
4. TB mounting bolts are clean and tight.
5. See if there is 12 volts coming out of the 50 amp breaker on the engine.
If TB5, here is the ts chart for it.
Wait, you're *charging* someone for this?Hey man, this is a different boat, not mine, but a client's. It is a 1997 WellCraft with a 5.7 2 BBL Mercarb. The ignition is Thunderbolt V.
How is the ignition module grounded?
It's attached to the main engine ground.
I meant the sensor inside the distributor. The module looks to be grounded through the harness.You told us earlier
I know this, but this is helpful information nonetheless.The main breaker is before the key switch. So that isnt it
Power goes from:
battery to main breaker
Main breaker to cannon plug
Cannon plug up harness thru adapter harness connection to ignition switch
Once ignition switch is turned on, power goes back to motor thru MOB switch to adapter harness connection to cannon plug to coil.
Clean every connection, you will find the bad one
This has a non-OEM dash-mounted kill switch that I installed last year. The wire connections are all heat shrunk and the kill switch only has .01 ohms of resistance. I have also had it bypassed for a long while with a jumper wire to rule it out for testing. It seems the actual wires themselves are the problem here because I'm seeing the voltage drop off for the entirety of the wire run.Check the plug in the harness by the MOB switch, check the plug in the harness by the Starboard aft corner
