Plandeck
Thread starter- Joined
- Jul 8, 2012
- 115
...I dunno...did this carb upgrade thing many years ago with a small British sports car and never found it made a difference...I may go back to the triple blade prop next year to see if it brings the revs up and sacrifice the enhanced reverse control at low speed...I guess I needed the reverse choke setup anyway for the automatic choke so I'm not sorry about the switch...but I'm still not satisfied with the tach installation...I now have the 2 wires to the instrument light hooked up to the running lights...and the hot wire for the oil lamp directly to the electrical panel...this allows the tach to run when the sailboat's electric switch is turned on even when running lights are off...but I still get the oil lamp on all the time...I thought if I ran the tach oil lamp hot wire to the oil switch hot wire that would work but no dice...I got no tach or oil lamp light...so I'm confused why the tach won't run without the oil lamp lit red all the time. I have another LED lamp on the oil switch which never lights. Should the oil lamp light initially when the ignition is engaged (the cut off switch lanyard in place) and then go out when the motor starts to run? I remember it used to work this way...AND THE OIL LEAK IS MUCH IMPROVED NOW WITH OIL DIP STICK READING HALF EMPTY..
