Re: 80hp 69' merc 800 choke issue
So on the wiring harness I connected the gray-wire(12v to choke solenoid) from the harness to the choke(electric) connector on the new ignition switch. When I push and the turn the key this should choke when I try to start? Would it be the same as the old mercontrol switchs were you had to push the choke button and turn the key?
