jathomps04
Thread starter- Joined
- Apr 23, 2003
- 27
I have recently aquired an older bass tracker with a 40 hp mercury 2 cylinder 80's model outboard engine on it. I have worked on it before and had it working but then the impeller went out. I replaced it and now with the new one in there is no water coming out the pee hole. I have double checked to make sure that there is nothing wrong with the lower unit assembly and everything looks good, including the impeller. What else can I check to find out why the water isn't exiting the pee hole. BTW, I have also checked to make sure the hole itself isnt clogged and it isnt.
